Having been in the navy I do know a thing or two about shining shoes. I recently bought a tin of Johnson's Paste Wax at Home Depot. I figured I could find some uses for it. Upon opening it the smell was powerful and very reminiscent of shoe polish. In fact the can itself says it's good for leather.
So as an experiment I wanted to see if I could shine my shoes with them. And just to see what else was possible I decided to try Collinite 915 on my shoes as well. These are the results side by side. From left to right; navy shoe polished shoe, Johnson's Paste Wax, Collinite 915.
On the left is my control. It's my actual navy issue standard dress shoe. Traditional shoe polish can be layered and polished to the point where the leather is completely covered and no longer visible. It takes a special technique of layering the polish and melting it in with the soft flame of a candle or Zippo lighter and then polishing with a wet cloth and buffing out with old school automotive polishing compound but no other person on base was able to replicate the shine and durability of my shined shoes. Other's have tried but their spit polish tended to crack and flake off and needed complete stripping and repolishing. Mine still has the same shine from 7 years ago since I got out with just regular touch up shoe polishing needed.
Above is a closer look at my shoe polish navy shoes. You can literally see the sharpness of the reflection and note there is no actual visible leather in the toes.
This is actually Johnson's Paste Wax. It definitely can be layered physically one layer on top of another. And built up to quite a thickness which can actually be measured. I tried building it up using the same method I used for my navy shoes. It behaves almost exactly like shoe polish. The layer I built up was comparable to shoe polish but the wax itself is more flexible and just tends to follow the fine countours of the leather preventing the wax from achieving a mirror finish. The benefit is layering it doesn't hide the leather like shoe polish does considering it's a clear polish.
Lastly was Collinite 915. I can say it's a disaster. It turned chalky in the pits of the leather, not as visible in the pics but it's definitely noticeable in real life. It definitely is a slick surface though. But I think I sorta proved to myself and confirmed that you really can't "layer" carnauba car waxes. At most second coats really just improve coverage kinda like Collinite says.
With shoe polish and Johnson's Paste wax you can if you're careful apply multiple thick coats and polish them to a nice bright finish. And it'll actually be a measurable layer of wax. Perhaps it's why it's so good at protecting metal from rusting as it does provide a measurable coating of wax, albeit it's a relatively soft one that can be scraped off. Probably the beeswax and paraffin waxes that allow it to build up, plus it's not as super slick. Which makes it good for flooring too.
Pure carnauba car paste waxes on the other hand like Collinite, I just couldn't get to layer. No matter how carefully I applied, melted and let dry, extra layers on top of the first coat simply wiped off the first one. That first layer seems to be a slick coating preventing more layers of wax from being applied on top of it.
And for all the non-believers out there, this is perhaps the most effective demonstration for wax layering. There's about no other surface that can take to building wax up into thick layers than fine shoe leather. If wax can be truly layered you should be able to measure it. You certainly can with shoe polish and Johnson's Paste Wax. Collinite not at all. Collinite did shine the shoe some and make it slick but it could not for all my shoe polishing and car polishing skill be layered to any measurable thickness.
