Originally Posted By: lilrobo
just joined here guys
i have a 1958 Chevy with a 235 6 cyl don't know the miles , now i have about 40 psi oil pressure when cold and when hot ( hot day ) i have seen 10 maybe 5 psi ,, i do have some rattling issues , like when it shifts from low to high i here something going on ,, i changed the oil when i first got it and use i think it was 15w40 fully sync oil and was told not to use that so i changed and started using straight 40 weight ,, that being said what should i use to keep better oil pressure, i am going tom overhaul the engine this winter but i want to drive it till then , i was told that 20w50 would be better ???
please help guys
thanks
Welcome to BITOG.
We run fleet trucks to very high mileages. Many times at over 100k miles they may begin to consume a bit of oil. We generally then go to a 40w to control that.
I would not want an older engine to be running only 5-10 psi under any kind of load!
