I just replaced the Royal Purple 15w40 in my Pontiac 400 with some Delo 15w40. I made some interesting observations. The RP only had maybe a hundred miles and three months on the oil. After hearing so many good things about Delo 15w40, curiosity got the best of me. One observation I made, oil pressure with the Delo was closer to the conventional 20w50 I have used than the RP 15w40.
RP at 850 hot idle was about 16 psi. The RP
at 3000 was 59 psi.
Delo at 850 rpm hot idle was about 18 psi. 1000 rpm the Delo was 20 psi, 1500 rpm 40 psi, 2200 rpm 60 psi.
The Valvoline all climate 20w50 I use to run had 20 psi at hot idle of 850 and would reach 60 psi by 1900 rpm.
I have to say, I was so used to running a 20w50, I still worry about using the lighter oil. But the Delo does not seem to be that different from the 20w50, only a few psi.
I am not knocking the RP 15w40 because my motor's valvetrain seemed quieter and smother with the RP 15w40. Should I stick with the Delo?Car still runs like a scalded ape!!!
at 3000 was 59 psi.
