Mobil 1 5w50 viscosity
Originally Posted By: default
Whoever rebuilt it did something wrong, that is not healthy pressure.
This.
The root of the problem needs to be solved, a band aid will not last long.
Originally Posted By: Blkstanger
Put a Melling oil pump in it. Problem solved.
A new oil pump doesn't fix the problem that causes low oil pressure, which is usually severely worn bearings.
