Short version - have a 2014 Infinity QX80 AWD 5.6L in the shop. It came for the known issues they have with the high pressure fuel pump lifter bucket worn thru and bad cam lobe. It also had P0011 and other timing codes. We replaced all chains/tensioners, cam lobe, lifter bucket, all the o-rings and even a new front timing cover due to damage from the lifter bucket and it's bore. All Nissan parts were used. We took our time and verified everything every step of the way - the chains are exactly timed. We also replaced the VVT solonoids as all part of the job. Starts up and we get....dang it....P0011 and a P0300. Studying AllData and ProDemand they each have verified fixes of: vvt solenoid, Cam sensor, crank sensor and chains. Well we know the chains are new so I, in a rare act, just fire the parts cannon and replaced the Bank 1 VVT solenoid and crank and cam sensors - cheap enough to do anyhow. BUT - STILL P0011 and P0300. Oddly enough P0011 is the bank 1 (P0021 would be Bank 2) but misfire counter shows cyl 2,4,6,8 which is bank 2 the right side. So either I have the bank 1 and 2 reversed or something else is wrong. I am diagnosing with BANK 1 as the driver side left bank and that coincides with what the service data says - but alldata and Prodemand have been wrong before.
Any tips on this P0011? We do darn good work and many times fix what other people/shops can't but this time it's my turn in the barrel![Rolling on the floor laughing :rofl: 🤣](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f923.png)
