Reading in a recent STLE Book that only 12% of the energy of the fuel goes into propelling the vehicle. You don't have to be a "Tree Hugger" to appreciate how bad and un sustainable this is.
One number in isolation doesn’t tell the story.
When you talk about “percent of the energy“, where are you starting the measurement, and where are you ending it? Do you mean fossil fuel when you say “energy”?
When you say “propelling the vehicle“ do you mean overcoming drag? Providing acceleration? Both?
The rest of the energy frankly ends up as heat. Nearly always does.
The question is - how efficient are other forms of transportation? Trains, for example, are fairly efficient. Much more so than cars. Busses a bit more efficient.
A gas turbine power plant is on the order of 40% efficient, the rest is lost as heat.
But when you lose some of the electricity generated to heat in the lines, as well as heat in the transformer, and heat in charging the battery, it turns out that perhaps an electric vehicle isn’t a whole lot better than gasoline vehicle in terms of the total energy in and number of miles traveled for that energy.
The big advantage of the true electric is regenerative braking. Instead of turning kinetic energy (created by using fuel) into heat via brakes, it is converted (not at 100% efficiency, but still) back into electric energy. Far more efficient than regular braking.
The true “tree hugger” advantage to BEV is that the electricity can be generated from a variety of “green” sources, that don’t require fossil fuel.
