Nah, not really. A plain old porcelain coated pan works just fine, as well as all of the stainless pots and pans.This is the thing. You are paying a lot to work around limits of induction and weight. You need to have enough strength to not warp and be light. Maybe you need to add some rare earth food grade metal in there as well. Then once the coating wears out you need to toss that expensive metal base away with it.
Or you can just use gas and anodized aluminum with teflon coating, or even cheaper non anodized aluminum and just ignore the warp, because gas don't care too much about the warp.
Is it not possible to put a stupid non-stick teflon coating on steel?
IMO There are no drawbacks to induction, except that you can't use aluminum pots and pans, oh, and no copper bottomed Revere Ware (remember those? BIG bucks today) either.
