In-Line disposable 5-micron purification fuel filter... ?
SWEDEN
( Petrol / Gasoline )
I need help to find a disposable 5-microns purification in-line replaceable fuel filter.
I have searched a lot but can only find with 10-micron degree of purification.
( Must withstand: 3.0 Bars / 303 KPa / 43.5 psi fuel pressure. )
What is your application and what part came out of the equipment? Give us something to go on.
Dieself fuel filters would do it, look at the filters for a smart for four diesel for example
What is your application and what part came out of the equipment ?
Powersport vehicle with direct injection directly into the combustion chamber Gasoline/Petrol engine.
An In-Line filter is already installed from the factory,
but completely unmarked in terms of degree of purification.
8 mm connections In/Out.
Can you tell us what the 'Powersport' vehicle is? If we know then we can get an OEM part number and ultimately figure out what it is and who makes it. It's much easier this way than trying to take some specifications and whittling down what might fit.
And with regard to the "Smart for four" suggestion... do you remember these little guys? The Smart car came in a 2-door also (Smart for two).
Can you tell us what the 'Powersport' vehicle is ?
Smart ForFour, with a Mercedes Diesel engine and an easily transplanted filter and support mounted on the firewall.
In various BRP Powersport vehicles, such as: Snowmobiles, ATV, UTV, Outboard engines.
BRP part # 513 034 047
...also in various Arctic Cat Powersport vehicles, such as: Snowmobiles, ATV, UTV
uses the same fuel filter.
Arctic Cat part # 1670-825
You're in luck. That is a common filter and is available for about $7 from Wix under part number 33095. I am sure Wix is available in Sweden.
It's at RockAuto for $5,75 too :)
You're in luck.
That is a common filter and is available for about $ 7 from Wix under part number 33095.
Yes, I have no problem getting hold of these existing filters.
The problem is that I would like to find a verified 5-micron filter instead.
:unsure:
