Import Multi-Vehicle, Valvoline vs. Castrol, VI?
Florida
I'm trying to decide between Castrol or Valvoline import multi to use in my 2006 Highlander with Aisin 3309/T-IV transmission. I used the Castrol in my Honda Element for 100K miles with zero problems. However, I noticed that the viscosity index for the Castrol is 200, where the Valvoline, a synthetic fluid, is closer to 150. This seems like a huge difference for two products that are essentially the same price. The question I have is, what is better in an ATF, higher or lower VI rating? For reference, the original Mobil 3309 fluid has a VI around 185.
My choice would be Maxlife
I put Castrol IMV in my Camry's U151E
Biggest mistake ever
It slipped, flared, banged into gear,and just didn't behave like it should've
I think that 6 month 5k time it was in there took some time off its lifespan
I bit the bullet and ordered the case of Mobil 3309 off Amazon, and the second it went in, it worked perfectly
I D&R'd the ATF in my s-I-l's 2004 Corolla with Castrol IMV @ approx. 140K. She wasn't sure if that was the original fluid but the IMV ran great and still looked cherry red when drained again 40K later. I recommend it in Toyota's that spec. 3309.
Maxlife has ran great in my daughter's Elantra that spec's SPIII.
In looking at the Valvoline IMV and the Maxlife, I noticed that the Brookfield Viscosity (?) is quite different, IMV is 18000 and Maxlife is 10200. If Brookfield Viscosity means anything, then this is a significant difference, especially since these are both synthetic fluids from the same company. Any thoughts?
