1990 Nissan 300zx- codes 32, 33, 34, 51 and 13.
32 and 33 are EGR related
34 is the knock sensor
51 is fuel injectors (turned out to be the harness/connector)
13 is coolant temperature sensor to the ECU
The last two I fixed, 32, 33, and 34 come on and off at random, doesn't really bother me.
The ECU is under the passenger footwell, behind a balsa wood panel under the carpet. Turning a potentiometer on the side of the ECU one direction, then back after a couple seconds makes the CEL blink a series of long-short patterns that gives the code number.
OBD I rules!
I had a 1991 Dodge Stealth twin-turbo that courtesy of being built by Mitsubishi, had an even odder method of CEL diagnosis. There is a factory data port used by the stealership which you can hook an analog multimeter up to two of its pins via alligator clips and the pattern of sweeps of the needle on the meter corresponds with each code.
