I would not take advice from that particular set of people.quote:
According to people I've heard from on audiworld who've had their engine replaced
Why is this? I thought the Motul 8100 0W40 and Esso XD-3 0W40 were both very sheer-stable oil with high HTHS numbers. Am I missing another important aspect of oil ratings?quote:
Originally posted by TooSlick:
Any 0w-40 will shear like crazy in that engine ....you are better off going for a shear stable xw-30 like Redline, Amsoil, etc....
In speaking to the service mngr. , we feel that they underfilled the car by 1/2 qt. So I had to top it off and start over, hence the change to the T&SUV. I would have brought it back and they would have told me everything was fine. Then when the problem really did arise they would have dismissed it. So they documented that the 300 miles are not counted and to take the test from starting after that.quote:
Originally posted by pastmaster:
V8Blitz,
How did the oil use test with the Agip Oil, through your dealer go? What determination? Do you have an "oil burner"?
I think the GC O-30, was the ideal oil, but does it meet Audi's warranty requirements?
I think you should give the Mobil 1 T&SUV, a chance, at least 1000 miles, and see what happens at least as mileage and use goes. Will the Mobil 5-40 meet Audi's warranty requirements? Then you're all set!
They did even better; they VAG'd it. It was scanned after the install and it had no codes thrown. The battery was not disconnected because the OBD on this car is such that it learns your driving dtyle evry 3500 miles. You can do a throttle reset if need be.quote:
Originally posted by JohnBrowning:
V8Blitz, My late grandfather would say you have more money then brains!!! Lets look at this for a moment. You are running an oil that has the right charteristics for the engine based on white papers. The oil is proven to protect well in most applications. It has been used by other Audi owners with good results. You have no quantifiable data. The oil is causeing no harm to the engine in any way.It cost $20 per 5 qts. or $4.88 per qt. and you want to drain it out due to butt-dyno results?
Even if you new exhaust system builds better peak HP and better peak tq. I doubt it builds better low end tq.! A free'er flowing exhaust seldom helps low end torque! It is a very common complaint after adding header's and big bore low restriction exhaust that low end torque is down! This was also rather common with so called "cold air kits"! A lot of computer systems have to relearn their optimum fuel and timeing settings for a vechile after the batery has been disconected. Most use fuzzy logic that is voltile and needs about 50 driveng cycles to relearn. THe same is true for adaptive shift patterns. I am sure if it was a good shop they disconected the battery to make sure they did not short anyting out!
While I am not arguing w/ you, I do wonder why Porsche and Mercedes and Audi for that matter all approve 0W-40 weight oils. They even name the Motul specifically.quote:
Doug,
I like the shear stable 5w-40/10w-40/15w-40 oils just fine - I particularly like your favorite Delvac 1. I have NO use for ANY 0w-40 formulation (even Amsoils') for the simple reason that I've never seen one that's even remotely shear stable.
If you can show me an SAE 0w-40 that won't shear in my Audi TT turbo, or any high rpm, multivalve engine like a BMW, I'll change my tune. By you know as well as I do that no such oil exists. Given current base stock and additive technology it's not possible to make a shear stable 0w-40.
BTW,I'm less and less impressed by "German Engineering" every time I drive an Acura or Lexus or have to take my Audi TT into the shop once again, to hunt for electrical gremlins.
Ted
Really? I've heard about this but I thought it was more urban myth than factual. I am interested and will try this. What exactly is the pumping the brakes part? What do you do? Can you tell me how it's done? I've also heard of a throttle reset that has you turn the key to right before the engine turns over and then to put the pedal to the metal for about 10 seconds. I've tried this and can't honestly say I've felt anything different. It's supposed to be good to do every few thousand miles or so.quote:
Originally posted by moribundman:
V8blitz, after any engine modification you are well-advised to reset the ECU. That has nothing to do with clearing codes. And yes, having a VAG-COM (I do) is nice and useful, but to reset your ECU (and to clear soft codes), you simply have to disconnect the battery for 30 minutes (pump the brakes a couple times, too). ;-)
Has Doug Hillary been coaching you ?quote:
Pressing the brake pedal will remove residual power.quote:
We understand why the Japanese, I personally drive a Kia, we can accept anything from the wonderful Czechs, but the French!!!! The sleazy French!! That's hitting below the belt, Aussie!quote:
Now if only GM and Ford in the US could play catch up to the Japanese and Koreans. Or even the Czechs and French..............
The VW factory representative in Vancouver Canada told me the other day that oil burning in new water cooled motors was perfectly normal as long as it did not get worse than 1 litre per 1000 kilometers.quote:
The oil consumption of even fairly new, water cooled, Porsche 911 engines using the Mobil 1, 0w-40 is just terrible, and should not be tolerate in an $80k vehicle.
Tooslick
