Hokiefyd
Originally Posted By: 1 FMF
now what are you going to do with the new pc? more than likely you can get by with a system similar to the amd setup I recently did...
Yes, I absolutely could use the system that you just built. The more I think about it, the more I don't necessarily want/need new hardware NOW, but I want to get out of my current cycle of buying new OOB computers every 5 years because I always max the architecture out soon after I buy them anyway. Even if I keep close to the same hardware specs I have now, but move into a standard ATX type case, I think it's worth it because I would/could have that machine quite literally as long as care to keep the case. As hardware improves, I can replace what I want to replace as I want to replace it, rather than springing for a whole new setup, as I have to with Dell.
As I look at options, I believe I will stay with integrated video, at least for now. Right now, I have the best video card I've ever owned in a computer system, which is an nVidia GS8400 with 512 MB of RAM. I think even the most basic of integrated video systems on a motherboard today will meet or exceed what I already have. I also think I would prefer a motherboard with USB 3.0.
I have two questions that came up yesterday evening as I was looking at this stuff.
For a basic-to-moderate home user like myself, the difference between AMD and Intel is largely going to be brand preference, right? It appears that there's a hair more value with AMD, but they appear to be pretty similar. I've personally owned both before, so don't really have much of a preference either way.
And second, I've only owned OEM stuff before, and the BIOS on OEM stuff is typically pretty simple. I assume that there will be an ASUS BIOS software on this ASUS board. Is there a lot more configuration/customization options in aftermarket BIOS software, or is all BIOS software generally the same or close to the same?
