I used that stuff in the past it wasn't that bad.Don’t laugh, but this stuff actually works well. Ace hardware has it.
Slick 50 Supercharged One Lube Lubricant & Protectant Spray 12 oz,
Slick 50® Supercharged One Lube Lubricates & Protects This proprietary formula is supercharged with synthetic additives to provide unsurpassed metal-to-metal lubrication and anti-wear performance. Apply for smoother, easier operation and long-lasting protection against wear on any metal surface...slick50store.com
What chemicals should a guy have in the shop for lubricating, penetrating oil, degreaser, cleaning etc? if you were to go on Amazon right now, what line up of chemicals would you buy to have in the shop for those basic metal tasks etc?
Never use concentrated SG or Purple Power on Al or MG. It will damage it. SeverelySimple green for mild damage free cleaning
Brake parts cleaner for areas without concern for painted finishes or trim plastic
Penetrating oil Kroil or PB Blaster
Lubrication I just started to use Lucas Red and Tacky in a spray can
Best motorcycle chain oil is Maxima chain wax
Why mess around like that? Just give the whole buggy a complete wash with gasoline. It's not just for the tank anymore.Degreaser, I usually use brake clean or gasoline. I use diesel to get tough sticker/etc petroluem based adhesive goo off containers/etc.
