If an engine uses oil, can you run a longer OCI?
NY
Discuss.
Example-if an engine uses a quart of oil every 3000 miles, and the sump capacity is ~3.75 quarts, can you get away with a longer OCI, considering that you're introducing a fresh quart every 3K?
This is my current situation with my Corolla. I'm going to send the oil out after 15K (Mobil 1 extended performance). Will report back with the results.
Originally Posted By: TurboTravis
Discuss.
I would use a High Mileage type of oil, but run it for the extended OCI. You would really use up the i that way, using its full potential, with an OCI like that.
Maybe M1 High Mileage?
I would feel comfortable using ANY High Mileage oil, though. That is what i meant by "using it all the way up and out." Not just M1.. but thats just me. All oils mentioned are good.
The short answer is, yes. The long answer is, yes, but stick with your plan to send out a sample and base subsequent intervals on the results.
FWIW, many with the EJ257 experience consumption, but I don't. Consequently, my goal of finding an oil I can run out to 10k miles may be nothing more than a pipe dream.
I would try an interval like 6k first. Then do UOA. OIl is cheap compared to an engine. Do it gradually. Really gradually.
Discuss.
That isn't burning oil to bad, I bet a thicker viscosity oil or maybe some of that STP oil treatment would slow it down. Or do what the others said and try some high mileage oil.
I wouldn't go too long, because if something is wrong such that you're consuming, then the byproducts will go into the oil that's left.
Mobil 1 High Mileage solved my consumption issue.
Discuss.
Have you thought about finding out why your car is using oil?
Discuss.
It uses oil because it's a 1995 Corolla with 250K on it. Considering that some auto makers consider 1qt per 1000 miles an ok amount to use on a BRAND NEW CAR, I think I'm doing ok.
The engine has seen oil changes with mostly Valvoline High Mileage every 6K for the last 100K miles.
I suppose you could run it farther but at only 3K mi per qt(which is nothing), I'd add the qt at 3K mi and change it at 6K or whenever it was low again... You could have a used oil analysis performed before the 6K mi(say 5500) to see how the oil is holding up, but for the price of the analysis you can change the oil and you know it's OK...
Originally Posted By: Clevy
With that kind of consumption just change the filter every 10000kms. Dont even bother changing the oil anymore.
MAYBE if it were using a qt in a K mile, but no way would I not change oil in this engine...
Look. If it uses a quart every 3000 miles. That means over 6000 miles half the sumps capacity is new oil with additives replenished. It's fine. You guys worry too much. The motor is in the last legs of it's life. Use an extended drain interval oil and change the filter every 10000 miles. Done deal.
If mobils EP line can go 10000 mile oci or amsoils SSO line will do 25000 miles use that stuff. And never change it again.
Geez man ... that doesn't give you much margin for consumption.
Yes, but top it off every 1500 miles (0.5 Qt) with that size sump.
Some large truck engine manuals actually come with a mileage scale based on fuel use and total oil (Including add oil).
I would consider adding a Fumoto Valve and simply taking a sample every so often. If you change the filter every 10,000 miles you will find you are going through 3.75 Qt every 10,000 miles. You may find that with EP their is no need for drains.
If mobils EP line can go 10000 mile oci or amsoils SSO line will do 25000 miles use that stuff. And never change it again. [/quote
My brothers Dodge Avenger with the 3.5 Liter, burns a quart every 400 to 1000 miles, now I told him to have the dealer fill it and have them track it to fix or replace engine, but he doesn't I guess that is his call. But I told him why would you change the oil at 6,000 miles, if you are throwing in a quart every 1000 at the minimum. That oily is refreshed by the time he hits 6,000 miles.
Heck my first car (75 Ford Granada) leaked/burned so much oil, that towards the end I just changed the filter. Because I was constantly topping it off.
If you go that long then at least use Mobil 1 High Mileage... Excellent oil but I would keep a close eye on the level and amount oil added. Mobil 1 High Mileage could cut down on the oil consumption...
Whatever you decide to do-do not use [censored] additives like STP or similar unless you are selling it or trading it. Then its up to your values.
