Was giving this some thought...
Say, you have, a 6-cylinder engine. I have the GM 4.3 V6, same as OVERKILL made post about in M/M forum.
And, say, that two of these pistons are now un-stuck from their cylinder walls, having been freed with a PB/seafoam mix, and 3lbs hammers.
So, basically, two cylinders (which two I do not know?) are more worn than the other 4. Probably will have less compression, and will have more wear.
I am conflicted. My oil pressure gauge usually shows one line on that funky digital gauge at full hot idle, and I can imagine the oil temp is around 100C, though I suspect higher. The 5W-30 is normal cheap conventional. And the engine does run fine, I see about 30PSI or 40PSI when revving and cruising, it only drops down at idle.
Should I bump up the oil weight wo a 10W40, or 20W-50? Those two cylinders being more abused give me concern, though she still purrs smooth...
Yes, it would be Supertech (cheapest stuff.) And they have everything from 5W-20 to 20W-50. Might try different oils in time, to quiet it down. Typewriter noise sometimes, could be the oil filter.
