I need help verifying the voltage readings on a car battery. I'm trying to figure out if I just had bad batteries or if the alternator is killing them. I want to make sure everything is OK so I don't kill a new battery.
Background info: Car with the potential issue is 1999 Toyota Avalon 180K. I had a 5 year old battery that wouldn't start after sitting for a few weeks. Took it out and saw fluid in the plastic holder tray that bubbled and fizzed up when i poured baking soda/water on it. Probably safe to say that that battery was done. I got a new battery from Advance (with the $40 off coupon of course
), put it in the 2008 highlander, and took the OEM highlander bat and put it in the Avalon. Drove it a few times over a few days, ran fine. Sat for a week and it was dead as a doornail, but I saw the map light switch was in the ON position
Since that bat is also 5+ years old I'm just going to write it off. I took a known good 6 month old battery from our other vehicle, put it in the avalon, and got various voltage readings. I'm not 100% sure what the voltage is supposed to be under different loads.
Here are the readings:
Car not running, no dome lights on (
) - steady 12.6v
Car running on idle (750rpm) - readings jumps between 13.99 - 14.08
Runing on idle, highbeams, dome light, radio, defroster, air conditioner full blast, hazard lights - jumps between 12.28 - 12.35ish depending on when the radiator fan clicks on
Do those readings indicate normal alt/battery function? Do I need to have someone rev the engine to a higher RPM to get an accurate reading? The car starts right up and runs fine like it always has. The battery light on the dash doesn't come on when driving and it didn't come on during the testing. I don't hear any unusual noise from the alternator and the alternator belt is only a couple of years / 30K old. Is there anything else I should check or can I put a new battery in it and be good to go?
