All microwave ovens are made by a Chinese company called Midea. They are the sole magnetron maker in the world from my understanding. So basically all of the internals are made by one source, with different exteriors and doodads.
31 years and still running strong. Homemade under cabinet mount with handy knife holder would be a pain to duplicate if I have to replace it.
have all stopped making magnetrons? Good heavens!
I stand corrected.
What I meant were consumer microwave magnetrons and the units themselves, mostly made by Midea.
I’ve managed to kill an Amana and a GE microwave now. All I know is don’t just replace the fuse if it popped, because it’ll pop again and a 12v 15A glass fuse is NOT an appropriate fix! Worked for 10 seconds then vaporized the thick power traces off the circuit board in a loud bang and puff of magic smoke.Throw me in they're all the same camp. Microwaves seem to last forever anyway.
The article/link even points out some specific exceptions. Just quickly skimming I came across this:So it's like when people say that all milk comes from the same local plant? Which is probably true for 90% but not for 100% of off-the-shelf milk. I also notice the incongruity between "Why Almost Every Microwave Is Made By" and "EVERY MICROWAVE IS SECRETLY THE SAME" despite the use of all-caps. Talking in absolutes is a tricky endeavor.
What are these covers? In what way do they prevent the oven from working properly?By the way, none of my microwaves have suffered magnetron failure. I have had to replace the mica waveguide covers, though. When they get contaminated by particles the microwave won't work properly or at all. The mica waveguide sheets are easily replaced.
You learn something new on BITOG everyday.By the way, none of my microwaves have suffered magnetron failure. I have had to replace the mica waveguide covers, though. When they get contaminated by particles the microwave won't work properly or at all. The mica waveguide sheets are easily replaced.
If you look inside the microwave oven you will see a silvery sheet covering the opening behind which the waveguide is located. The sheet is made from mica, a flakey, layered mineral that has dielectric properties. This cover prevents particles from falling into the waveguide. Over time the waveguide cover deteriorated due to moisture from heating food and food particles. The latter will cause shorts that can damage the waveguide. If you hear sizzling noises or see sparks flying inside your microwave oven you better check the waveguide cover for contamination or damage. Even if you prevent food from splashing in the microwave oven by using a cover, after many years of use the cover will eventually deteriorate. It's easily replaceable.What are these covers? In what way do they prevent the oven from working properly?
