I appreciate the tip re: the better tip as to a four cleat version. I have a AZ or Advance Auto Gr. gun which will clamp on a fitting and not slip off. But when you try to remove it, it won't pop off. I have to exert excessive force and you feel like you are going to pop off the grease fitting by the threads. Any specific recommendations on 'tips' by brand and where to purchase?
Regards the gun leaking. I have had that happen to me also. I had heard it was the grease separating or breaking down. The leaking is a clear fluid which is a by-product which occurs when the grease separates. This sourse says the more expensive Green Grease won't separate. Has anyone tried Green Grease? I was going to try the Mobil 1 synthetic grease, but may try the Green Grease instead.
