Originally Posted By: IndyIan
I think there is ABS and ABS, when GM first starting putting in on Cavaliers we test drove one and it pulsed maybe 5 times a second on gravel. It didn't seem very refined anyways.
Next we had a 94 Mazda 626 V6 with ABS and it worked very well on all conditions. Even though they tell you to mash the brake pedal with ABS I think it works better when you threshold brake, applying more force until you hear a click or two from the ABS system and then hold the pedal there, the tires should spend more time at maximum grip then the rapid locking and releasing of mashed pedal ABS. The mazda seemed to have amazing brakes in general and the only time I recall the ABS kicking in was on snowcovered roads and I was threshold braking.
Ian
Theoretically, I'd agree with this. Alas, I suspect that most drivers are not well versed enough to work the system by modulating pedal force so as to keep themselves just short of the ABS activation threshold. So I'd advise, at least generally, that drivers just mash the pedal as hard as they can, and use the wheel to steer clear of trouble. For those of us who understand the systems, and have the ability to do better, of course, that makes more sense.
My vote is to use ABS, period. No system is perfect, and if you operate in an environment where you often find the limits of ABS (snowy roads as the OP described), then perhaps you MIGHT consider a switch or pulling the fuse, but for the vast majority, keep it active.
