If you clear the EVAP leak code, it leaves the misfire diagnostic pass intact, so it can in fact finish the roster of I/M monitors faster.
The 2 incomplete rule is a Cumb cty ME rule, may not be the same in NY.
You can't only "clear" the EVAP leak code. Here is the skinny on it
CAUTION: Erasing the Diagnostic Trouble Codes may allow the scan tool to delete not only the codes from the vehicle’s on-board computer, but also “Freeze Frame” data and manufacturer specific enhanced data. Further, the I/M Readiness Monitor Status for all vehicle monitors is reset to Not Ready or Not Complete status. Do not erase the codes before the system has been checked completely by a technician.
That is why a great mechanic will follow the drive cycle and get the On board readiness monitor to run again and making sure it succeeds before calling the repair done. If you do find such a mechanic, marry him
I believe NY state (and almost all, including CA) allow 2 incompletes for MY2000 and earlier. CA was lone holdout for a while but now it too allows 2 incompletes. There is still one gotcha if your car fails the test for *any* reason; the retest has to have your cat efficiency test completed, otherwise you fail the retest.
Given that demarpaint's vehicle is pretty new, I know that he does NOT get 2 incompletes :-( I *think* he is allowed 1 incomplete but I will have to look up the NY emission website.
Also the monitors have relationship i.e. some monitor can only run if some other monitor has completed successfully. Hopefully, no other monitor depends upon evap completing successfully.
