dnewton3
Staff member
I do believe the EV would probably be better overall; in that we agree.Since no two vehicles can travel the same patch of ice or snow, this can never be proven.
But real world experience here, having owned and driven ICE with good AWD systems, and EV, on the same tires, I can tell you the EV is the better tool for the job. You cannot argue with the physics of a propulsion system that can infinitely and instantly modulate power from 0 rpm. Just can't be beat, all things equal.
What I disagree with is how the video purports this advantage to be monumental, and it's probably not.
If you equalized the vehicle weights, and the tires, and the surface, the EV advantage would likely be much less.
- In the first part of the video when they all went uphill on a unique path, the EV (using traction control) smoked the other two by a very wide margin. That margin of victory would have been much less if the other criteria were "apples to apples".
- In the off-camber portion of the test, again if they all had the same surface and weights, the EV may well have still prevailed, but by a much lesser margin.
Honestly, given that the biggest variable is driver skill in poor weather, the topic of EV superiority over AWD ICE systems is kinda moot, IMO.
