Originally Posted By: wtd
Back in the early 2000's, I used 5w30 Mobil 1 in my 1998 chevy truck with the 5.7L V8. I did 3,000 mile oil changes because that was what the manual stated for the type of driving I did.
When my warranty was gone, I decided to take the Mobil 1 to 5,000 miles and do an used oil analysis to see if the oil was suitable to go that far. Mobil at the time claimed you could extend oil changes.
My used oil analysis came back with elevated levels of lead and some of the other elements. Blackstone Labs recommended staying at 3,000 mile changes. I did multiple used oil analysis after that on this engine at 3,000 mile intervals and the results were better but not great, especially for what I was spending on oil and BL still recommended staying at 3,000 mile intervals.
I decided to go back to a conventional oil which I chose Chevron, and my wear numbers improved quite a bit and BL said to start going up to 4,000 mile intervals.
I'm glad I didn't blindly follow some of the advice on here that I could extend my oil changes because I was using Mobil 1 full synthetic because my used oil analysis results didn't support that belief.
Not every oil works good in every engine. Back then as in now, Mobil 1 was highly regarded and I used it religiously but my 5.7L engine and the 3800 in my ex-wife's 98 Grand Prix GT didn't like it either as the used oil analysis on it were not that great either. Both engines had tapping noises while using this oil and used more oil than I liked. The change back to Chevron conventional in both of these vehicles caused the tapping noises to go away and decreased the oil usage.
Since then, I have not used a full synthetic and have not used a Mobil product. I'm sure Mobil 1 is better than it was back then, but I lost confidence in it and have no desire to try it again.
I just don't think a synthetic is needed in most driving situations and I have yet to see any good evidence to prove that you get longer engine life by using them.
Wayne
Actually if you follow used oil analysis you will see GM engine often show very high metals compared to other brands. However as we know this does not translate to actual measured engine wear. GM engines are known to be long lived engines. I have a friend that had 325K on his 99 Gm 5.3 doing 15-20K OCIs with Mobil 1 5w30. Finally dumped the truck after his 3rd trans failed, but the engine still ran strong.
I'm not saying you can't get long life with synthetics or Mobil 1 for that matter but I also did not like the engine noise or the oil consumption I was getting while using Mobil 1. Along with the elevated wear metals, I just didn't feel like I was getting my money's worth. Obviously you get good results with Mobil 1 in your vehicles and it's a good match. Since I still read about some instances of noisy engines using Mobil 1, I'm not willing to try it again.
I still own this truck today and while it only has 125,000 miles on it now, it still runs like new using conventional Pennzoil. Since I only put about 2,000 miles a year on it these days, a synthetic would be a waste.
I have a friend at work that also has a 1998 chevy truck with the 5.7L and he has 325,000 miles on it using conventional oil.
Wayne
Wear metals from a typical 25 dollar used oil analysis don't really mean anything. A used oil analysis is not a good method to measure wear and to be honest high wear metals mean nothing.
There is a thread here posted by Doug Hillary iirc where he ran the oil til iron hit 100 ppm,then changed the oil.
After 1000000 or more miles the engine was torn down and parts were measured and guess what,no wear.
Iirc he reused most of the old parts in the rebuild.
So high wear metals don't mean high wear.
A 25 dollar used oil analysis is meant to check the serviceability of the oil,not measure wear. It's just that simple. You are reading more into the used oil analysis than you should be.
