Originally Posted By: Bill in Utah
Originally Posted By: Steve S
It is not the oil is is poor designing.
Yeah all those Toyota's with the loud timing chains due to poor designed tensioners.
You see the complaints on that ALL the TIME!
Originally Posted By: ARCOgraphite
Just for fun, I put the hated one in - syntec 5w30 with beloved Wix 51396 larger filter (51394 is wix book#). Just 10mins ago finished the fastideous OC at 24025 miles. I have ALL the used filters catalogued & saved for this car from day-one.
You asked on how to get it fixed if it does not do it all the time.
First I'd suggest you run the CORRECT oil filter. It is NOT NEEDED to go oversize and IF your engine DOES have a issue, you have just given Toyota a great reason to say "it sucks to be you".
Go back to the base line. CORRECT filter, CORRECT oil and drive the car. *IF* it has the issue (and you say it does all the time IE the "NEED" for your oil "cocktail") it SHOULD do it ALL the TIME with the "poor performing" Conventional oil.
Correct?
So if it is doing it then take it to the dealer and let them work on it. 25k miles is NOTHING. I've got almost 150k and other than some problems I had due to a extended OCI with a bad oil/filter combo (which was a one time problem and never came back again once I went to what I KNOW works) I've had no problems with the tensioner or the engine.
Bill
The toyota filter made in Thailand (pn 90915Yzzf2) are GARBAGE. Motor will stick tensioner IMMEDIATELY upon using one of these low flowing pieces of junk. Happens time and time again eveytime I try one. The oil is correct IMO. Car runs fine on syn - just trying to fine tune smoothness and revvability/power without having to make a coctail. The Inferior (in rthis app) Synpower required a coctail. This motor cant run conventional oil - I think Bill has a sticking point that the "magic" conventional doesnt work in all engines. WEll guess what - it doesnt! Go to Yaris world and see ALL the engine noise complaints. Most folks dont understand this is not an inherently noisey, powerless or vibration prone motor, The guys running PP and Purolator or Wix filters have NO complaints. I'm a big boy, beenn around a dogs age, I built many a race motor putting out 1.5H/cu-in and I am a NIASE Master engine tech. I'm think I'm done with this thread. Thanks all for your advice.
