Originally Posted By: ARCOgraphite
The Yaris 1.5L 1nzfe is an advanced engine with high specific output - 4v, chain driven DOHC, FLAT tappets, variable valve timing with intelligence, ST-Steel tube headers. 105Hp, 5sp M and 2300 lbs make for a peppy ride. NO one oil I have tried has worked exceptionally well. The best so far has been Motul 8100 econergy 5w30 SL. Wanted to try Motul xmax or Elf/Total quartz energy 9000 but didnt want to mail order ... Trying American "syns" again. I've been down the PP and GC road and was nonplused.
-70hp/l : 95% of 4 cylinders out of Japan/Korea
-4 vales per cylinder: 95% of 4 cylinders out of Japan/Korea
-some form of variable valve timing and/or lift : 75% of 4 cylinders out of Japan/Korea
-DOHC : 60% of 4 cylinders out of Japan/Korea
-headerS: 0.0% of 4 cylinders out of Japan/Korea
Not sure why this engine needs super expensive synthetic oil to run properly....otherwise, Toyota has failed.
The average person who buys a $15k car that gets 40mpg is not going to maintain the vehicle particularly well....or if that is too presumptuous, let's say they won't go out of the way enough to look at oils that are costing $10+/qt.
