Originally Posted By: Cujet
Originally Posted By: RamFan
There are two main advantages to synthetic; extended drain capability and cold start protection. Extended drains can be disputed, many OLMs that prescribe conventional usage are running over 6k miles (6k seems to be the magic number for when a lot of people say a synthetic should be used). Cold start definitely cannot be desputed. Synthetics flow better than conventional oil in cold temperatures,
I could not disagree more. As a mechanic here in sunny, warm South Florida, I regularly see the effects of "conventional" oil changes. Especially in vehicles with adjustable cam timing, cam phasers, and so on. I also see vehicles with incredible amounts of sludge, timing chain problems, hyd lifter problems, stuck rings, coked up turbo's, horrible valve deposits and on and on.
The only reliable way to avoid such problems is to choose a product such as M1, and change regularly.
I'm sorry to admit that most new vehicles are "high tech" and expensive to repair. Why anyone would chance going the recommended OCI on conventional oil is beyond me. Clearly, there are great conventional oils, but there are very bad ones too. And, you have no way to know, until after the fact.
+1 Cujet,
I'm glad to see folks like yourself that see the internels of engines every day report on the advantages of quality synthetic oils rather than opinions gleened from those that haven't got a clue what makes an engine go round and round.
Thank you Sir.
