I bought my first TPMS tool
Staten Island, NY
Because @Trav was right, once you get going with tools, it doesn't stop
It's an Autel TS508WF, which is just a 508 with WiFi added for easier updating
Those updates are free for life, respectively
It does OBD relearns, which I need with several Toyota products wandering around
Comes in an agreeable fabric bag with mini USB charger cable and OBD2 cable
Once out the box, had to get it registered and updated
Then I charged it, then I took it outside for a try on some cars
Checked all the sensors on the Milan fine 👍
Did OBD comparison check on Project xB just fine
Struck out on my dad's work issued 2010 Prius, the RF doesn't have a sensor, just a rubber stem
Both front tires are down to the cords, so when it goes in for maintenance, I'll see if I can talk them into swapping on a rim with TPMS sensor
They're usually amicable to my requests (they thought I was Moses when I introduced them to the spill free funnel)
Now this demonstration was on a vehicle with fully functional TPMS, but I might have a vehicle drop in with a malfunctioning TPMS as a real test
I posted about that Avalon I had in for maintenance a few weeks ago
A tire shop failed twice to put the light out, perhaps I will succeed 💪
If I can fix it, I could charge 😮
Imagine that, profit 🥰
I never profit 😭
This is a full sensor ID capture, and OBD relearn on a 2009 xB, which has no on board programming capabilities
Fairly responsive
Capturing the data
Looking at the data captured
Following the wizard
Writing the sensor IDs
Apparently some Toyota vehicles need the TPMS system "unlocked", to accept new data
Apparently Autel has baked that into the process, but it makes the dash really confused for 30 seconds or so
Success 🤌
If you have TPMS DTCs, it'll show them to you, also if the light is currently on or not
This screen with it's green indicators is showing the OBD data is jiving with the stored data
Comparing captured data vs OBD data
"Before and after" if you will
Concluding with applicable notes
Overall, a fairly intuitive and speedy way to deal with TPMS
Granted, I didn't really fix anything, as nothing was broken, but proof of concept 🤷‍♂️
So far, I've tried it on
xB, Milan, XT4, Prius, and it's always given usable data
I don't know much about Autels proprietary branded MX universal sensors, as I don't plan to use them
If one needed service, I usually would have my tire shop swap in the correct OEM (Schrader/Denso/TRW/Pacific) sensor as needed
I'll update the post if I truly manage to solve anything with it
I triple dog dare you to get the HF tire changer so you can break beads and sneak new sensors in.
If you don't break the inboard bead, you won't move the tire on the rim, and won't have to rebalance anything.
I've got the same sans WF and used it on an '11 Camry when swapping wheels from alloys to steelies (all seasons vs snows). It worked.
If you get the HF tire changer go ahead and pick up a hood, gloves, grinder and their highest-reviewed welder on YT. Then go to HD and get a hammer drill, SDS bit, drop-in concrete anchors and the appropriate driver. Trust me. Mine gets more use than it should but it needs improvements to be truly useful (including the bead breaker fo sho)
The Autel MX sensors work well. I have been using them for years. I have a bunch of ts508s because our vendors usually kick a deal around with a free ts508 with the purchase of a brick of sensors (20 sensors). I prefer the TS608 personally because the screen is much larger but the 508 gets the job done.
STOP MAKING ME SPEND MONEY 😭
THIS FORUM IS TRYING TO BANKRUPT ME 💳
I thought I drew a line at the $20 PTFE silicone and the $30 Shin Etsu grease, but you all find new ways to make my mailman suffer 🥵
I don't have the space 😒
But it would be nice
You can't go wrong with the Autel TS508WF. My workplace uses a TS508 (same tool minus Wi-Fi updating capabilities) to perform TPMS service and repairs on a variety of makes and models. With those tools, they can batch program up to 16 Autel MX-Sensors at the same time. Useful if you have a fleet of four cars of the same make, model, and year. Typically, programming four of those is plenty enough. You won't believe how a box of 20 were sold out instantly when we first used them. I was impressed with the TS508, I actually bought one myself.
