The Problem:
I have a small Ford tractor with hydraulic power steering. It specifies plain hydraulic fluid and I have changed it as well as changed the filter as part of normal maintenance. The tractor is commonly used with a loader (front mounted) and when the loader is on and the tractor is warmed up, the extra weight up front makes the steering heavy unless the rpm is bumped up by a few hundred revs. With the loader off, there is no problem. This performance has been consistent in the five years I have owned the tractor, even after rebuilding the steering box (for leaks) and replacing one hydraulic cylinder (for external damage), so have come to regard it as "normal."
The Observation:
I noticed that when the tractor is cold, the steering is not so heavy, even when the loader is on. For the first 10 minutes of operation (or so) the steering feels "normal"... like the loader is not attached.
Ideas: I'm still researching the oil I use (a Mystic product) as to the exact viscosity and other properties, but it seems to me that:
1) The viscosity is higher before the oil warms up, so;
2) Hydraulic assist is better with higher viscosity oil, so;
3) Either this is a fluid issue, or;
4) Perhaps the pump is weak and the higher viscosity fluid pumps a little better and masks the weak pump,or;
5) It really is normal, but:
6) Perhaps a higher viscosity fluid would help operation with the loader on, which is most of the time.
I will pressure test the pump, flow rate it if I can. Anyway, not a critical problem but any observations and thoughts appreciated.
The Observation:
