Usually if they're hung open, they cause a rough idle.
Those are probably gummed up or just slightly bound up and stuck where they are at.
Do they have a pin hole in the body for pressurized lube feed? If so, you can first try putting the tip of oil can up to them and trying to pressurize them apart. If that fails, try shop air, BUT- BE CAREFUL!!! Those little pistons can come out of there with surprising speed and force with 100+ psi air behind them!
