It is certainly an impressive package for a mini pickup.but the average mpg is 39.9
But if we’re only fixating on the MPG and 0-60 time, there are lots of options with those metrics nowadays.
Packs for the newer models are significantly more expensive; the increase started around the mid 2010 era. Anecdotally, the packs in the newer models seem to last a lot longer.We did replace the battery at 130,000 miles; a Prius indy came out and installed a new Toyota factory unit for $2800. So much for catastrophic battery replacement costs.
Politics is a no-no dude.Wisconsin Republicans jacked the registration fees on hybrid vehicles because they're "woke."
That battery will be under warranty for the next 10 years. I can find used factory batteries for a later model -- 2016 -- Prius for a few hundred dollarsPacks for the newer models are significantly more expensive; the increase started around the mid 2010 era. Anecdotally, the packs in the newer models seem to last a lot longer.
For example:
https://parts.longotoyota.com/oem-parts/toyota-battery-assembly-hev-su-g951048146
Oops, sorry.Politics is a no-no dude.
You have forgotten the decade where most of Georgia's I-95 was completely torn up. I swear they tore it all up then left for 10 years.My 2025 Accord hit 3000 miles yesterday which is mostly Interstate use with an overall 54.6 mpg for the 3000 miles.
The roads from MD to Florida are far from ideal. Probably the worst I've seen in decades..
Every time I went through Georgia i felt it was hotter than FloridaYou have forgotten the decade where most of Georgia's I-95 was completely torn up. I swear they tore it all up then left for 10 years.
It was. The Florida peninsula gets a breeze - keeps things moving. South GA / Lowcountry SC stagnant swamp air. Its how we won the Revolution. Made the Brits chase us around the swamps for a summer, the mosquitos got 2/3 of them.Every time I went through Georgia i felt it was hotter than Florida
That's the issue. The used batteries are always cheap when the vehicles are newer and under warranty -- because no one needs one. It was a similar situation with the Gen 2 and 3 Prius.That battery will be under warranty for the next 10 years. I can find used factory batteries for a later model -- 2016 -- Prius for a few hundred dollars
The fifth generation Prius, model years 2023 and later do have increased power and acceleration in contrast to the prior generations. My guess is that you own one of the earlier models.As a Prius owner I'm wondering where this increased power and acceleration people are claiming for hybrids is? Maybe they got most of mine? Ours could use an extra hamster or two.![]()
