It is certainly an impressive package for a mini pickup.but the average mpg is 39.9
But if we’re only fixating on the MPG and 0-60 time, there are lots of options with those metrics nowadays.
Packs for the newer models are significantly more expensive; the increase started around the mid 2010 era. Anecdotally, the packs in the newer models seem to last a lot longer.We did replace the battery at 130,000 miles; a Prius indy came out and installed a new Toyota factory unit for $2800. So much for catastrophic battery replacement costs.
That battery will be under warranty for the next 10 years. I can find used factory batteries for a later model -- 2016 -- Prius for a few hundred dollarsPacks for the newer models are significantly more expensive; the increase started around the mid 2010 era. Anecdotally, the packs in the newer models seem to last a lot longer.
For example:
https://parts.longotoyota.com/oem-parts/toyota-battery-assembly-hev-su-g951048146
Oops, sorry.Politics is a no-no dude.
You have forgotten the decade where most of Georgia's I-95 was completely torn up. I swear they tore it all up then left for 10 years.My 2025 Accord hit 3000 miles yesterday which is mostly Interstate use with an overall 54.6 mpg for the 3000 miles.
The roads from MD to Florida are far from ideal. Probably the worst I've seen in decades..
Every time I went through Georgia i felt it was hotter than FloridaYou have forgotten the decade where most of Georgia's I-95 was completely torn up. I swear they tore it all up then left for 10 years.
It was. The Florida peninsula gets a breeze - keeps things moving. South GA / Lowcountry SC stagnant swamp air. Its how we won the Revolution. Made the Brits chase us around the swamps for a summer, the mosquitos got 2/3 of them.Every time I went through Georgia i felt it was hotter than Florida
That's the issue. The used batteries are always cheap when the vehicles are newer and under warranty -- because no one needs one. It was a similar situation with the Gen 2 and 3 Prius.That battery will be under warranty for the next 10 years. I can find used factory batteries for a later model -- 2016 -- Prius for a few hundred dollars
The fifth generation Prius, model years 2023 and later do have increased power and acceleration in contrast to the prior generations. My guess is that you own one of the earlier models.As a Prius owner I'm wondering where this increased power and acceleration people are claiming for hybrids is? Maybe they got most of mine? Ours could use an extra hamster or two.![]()
DependsIs there any benefit to owning a hybrid and living in a rural area?
The Honda dual motor setup is optimized for highway mileage. If you do a lot of constant 45+ mph driving they might be worth it in gas savings. Again run your own ROI.Is there any benefit to owning a hybrid and living in a rural area?
Our normal driving habits are usually either a 24 mile round trip or 60 mile round trip. There is some city driving when we get to those towns.Depends
If all you do is buzz around the county. Maybe just ev
Take some long trips then hybrid
To me the Honda CR-V Hybrid is out of the running. The lowest trim package is the Sport and it comes standard with a moon roof. I don't like moon roofs.The Honda dual motor setup is optimized for highway mileage. If you do a lot of constant 45+ mph driving they might be worth it in gas savings. Again run your own ROI.
EVOur normal driving habits are usually either a 24 mile round trip or 60 mile round trip. There is some city driving when we get to those towns.
It is a common misconception that hybrids do not provide any benefit during highway driving. In both my Prius and my TX500h, the two powertrains are blended together and work simultaneously under all conditions. During highway conditions the electric motor provides additional power and reduces load on the gas engine.Our normal driving habits are usually either a 24 mile round trip or 60 mile round trip. There is some city driving when we get to those towns.
