Got a 2008 Rheem AC unit outside, and it will no longer keep the house, in 100+ degree weather at a reasonable temp. If it runs all day it will maintain 81 deg. at best, when it gets over 105 not so much.
So a quick investigation shows that the 1" copper line from the unit to the house, about 18' long, has insulation that needs repair/replacement. I took an IR thermometer and the temp as the line leaves the unit is around 75° rising to around 85-88° as it enters the house. What should the temp be as it leaves the AC unit?
