Do they actually check the oil when doing a safety inspection there? They don't here.quote:
Originally posted by Gary Allan:
Annual safety inspections usually don't let this sort of stuff happen.
I heard a story about a woman buying a car and when they asked her about her trade-in, they asked if she had the oil changed. She said:quote:
Originally posted by JHZR2:
She must have been a typical woman maniac driver.
Do you have state administered inspections? It's all private here. It's not part of the safety inspection ..but no shop is likely to give up the opportunity to sell another service. Whether it's Firestone, Pep Boys, or your dealer ..the service writer is always going to suggest the added service. The service manager (at least for PB and the other chains) is going to instruct the wrench to seek out and expose other services ("Mr. Allan ..your belt looks pretty lame. Would you like us to charge you $100 to change it since we can't find anything really big to bone you on?"). IM failures are virtually an automatic tune up ...etc...etc. Assuming that you're servicing it at the same place ...the records will indicate that you're way over due for an oil change. They would bring that to your attention.quote:
I think he said he was leasing it, meaning it is still owned by the dealership(?)quote:
Trade with a BIG HIT on something else....
My semi-educated guess that a complete rebuild for this would be in the $3000-$4000 range.quote:
So, how much does a rebuild of one of these run???
many states that DO have inspections prohibit the inspection station from also doing repairs for just these reasons (bilking the customer and holding inspection certification hostage for bogus repairs). It's the law in Texas at least.quote:
Is this a highjack? Probably ...sorry![]()
This vehicle obviously never saw the inside of a service center in 20k. If it did ...someone really dropped the ball. She had to have blown off the recommendation and forgot to follow up on it later.
Good lord, the oil hasn't been changed in 20K and you think an idiot light (which probably DID turn on and was summarily ignored by the idiot driver) is going to save that vehicle?quote:
Originally posted by JeepZJ4.0:
1. No oil pressure low light? There is a gauge but there is also a light, actually two lights. Most cars have a "Check Gauges" light as well as the oil pressure light. My Jeep has a gauge and a light. That's a failure on Ford's part, which in turn could have prevented this.
It's a pressure light, not an oil level light, and it probably was flickering on and off in turns and such long before the oil went away.quote:
Originally posted by georgeyew:
Did the oil light ever come on? Isn't there suppose to be a warning light long before the oil is all gone?
They also aren't breaking in. All that crap from break-in in the oil has been circulating throughout this engine for 20K, which I am sure didn't help it decrease it's oil consumption.quote:
but at the same time, none of the cars that I or my parents or girlfriend own loose any oil over 6-15k mile OCIs, some on syn, some on dino.
First off take a deep breath. It seems like you are posting with great anger.quote:
So was there really NO oil in the engine, or was it just low? Was the engine really SEIZED, or just wouldn't start? I think the first thing to do is diagnose what the real problem is before your friend tries to get a new or rebuilt engine. Find out what's really wrong, then fix it.quote:
Originally posted by jeepzj:
The car is now home after towing it to his mechanic and topped off, or filled up, the engine with oil.
Why not? Someone screwed up and doesn't want to take responsibility for what happened.quote:
Typical oil pressure lights work as described below:quote:
How do you know it flickers?
I really doubt that the light failed given the simplicity of the circuit I have described above, but even if it has, simply turning the key to the ON position without starting the engine will "prove out" whether the light operates. This is also a standard design feature found in most cars.quote:
When I said a failure on Ford's part, I meant a failure of the light coming on. There's a large gap of assumption going on.
It also stinks that they apparently desire to commit fraud as opposed to owning up to their mistake and doing the right thing. The original post stated all that needs to be known about this situation which is:quote:
I'm just being optimistic. Put yourself in yourself in her shoes, or even the husbands shoes...I feel sorry for them. It stinks that this happened.
