Originally Posted By: DS9
Excellent point.
First post here (below) is wrong.
Originally Posted By: Benito
HTHS viscosity is more important than grade.
The Euro oils must all have a minimum HTHSv of 3.5 regardless of if they are xw30 or xw40.
Some europian oils (oils for european cars) have minimum HTHS of 2.9 mPa.s.
Page 5 http://www.acea.be/uploads/publications/2010_ACEA_Oil_Sequences.pdf
C1 Stable, stay-in-grade oil intended for use as catalyst compatible oil in vehicles with DPF and TWC in high performance car and light van diesel and gasoline engines requiring low friction, low viscosity, low SAPS oils with a minimum HTHS viscosity of 2.9 mPa.s. These oils will increase the DPF and TWC life and maintain the vehicles fuel economy.
Warning: these oils have the lowest SAPS limits and are unsuitable for use in some engines. Consult owner manual or handbook if in doubt.
C2 Stable, stay-in-grade oil intended for use as catalyst compatible oil in vehicles with DPF and TWC in high performance car and light van diesel and gasoline engines designed to be capable of using low friction, low viscosity oils with a minimum HTHS viscosity of 2.9mPa.s. These oils will increase the DPF and TWC life and maintain the vehicles
He isn't wrong, but neither are you neighbour. Of course from our European stand point there's at least four different ACEA specification oils amongst twelve overall for passenger cars only as you posted earlier that specifies lower HTHS values.
But for Americans and Canadians Euro spec oil is only A3/B4 since all European cars sold there are using that, except maybe Volvo.
Excellent point.
