HPL PCMO 5w-30 (Base) VOA
Sacramento, CA
Here's the base HPL PCMO 5w30 VOA:
I do understand that many elements which show up have multiple forms ("zinc" for example has many forms such as ZDDP, etc)
But I do have to wonder why so much sulfur??? Generally that is corrosive when it is combined with moisture (sulfuric acid), and also VERY detrimental to catalytic converters. (Hence ultra low sulfur fuels ...)
So is that sulfur in some form that otherwise does little harm because it's some variant of "normal" sulphur?
And is that why the TBN is so incredibly high; to offset the anticipated sulfuric acid from extended OCI?
The sulfur and crazy high tbn got my attention too. I know it’s a great oil, just wondering…
Insanely high base number and this is their entry level motor oil.
Thanks for sampling.
The magnesium is 2000+ ppm that very high.
A conversation with Dave of HPL suggested 10k OCI and a filter every 5K. A high base number would make sense.
Wasn't the Royal Purple Synerlec additive a heavy sulphur-based additive? People used to speak pretty highly of it.
Thanks for testing this oil. I'm sure it will help some decide whether to use it or not. High TBN & detergent.
7864ppm Sulfur. What is that? It says additive. Maybe associated with the molybdenum.
Sulfur containing compounds in lubricant Additives:
ZDDP (an ester of Zn[(S2P(OR)2]2); Zinc, Sulfur, and phosphorus.
Spikes, H. "The History and Mechanisms of ZDDP". Tribology Letters. 17 (3): 469–489, (2004-10-01).
Calcium and Magnesium Sulfonates
Molybdenum Dithiocarbamate or MoDTC (recall that a MoDTC compound formula is C4H8MoN4S8), or 4 carbon atoms, 8 hydrogen atoms, one or more moly atoms, 4 nitrogen atoms, and 8 sulfur atoms.
So any DTC compound is on the order of C4H8XxN4S8, where Xx is the metallic element containing one or more of the metallic atoms to create this organo-metallic compound.
More Calcium and Magnesium sulfonate detergent included in the blend will mean more reported sulfur and higher TBN.
Moly additive will do this as well.
I think people just forget that these additives have sulfur.
Added to the VOA Database. I'm disappointed that Wearcheck does not test for starting Oxidation on virgin oil. I saw your Used Analysis of this oil and they list Oxidation there. Why not on virgin oil?
I also noticed they use D2896 TBN for both new and used samples. This method is only supposed to be used on virgin oil, never on used oil. 🤷
Was curious about the oxidation value as well.
I can email them to ask a bit later this morning. Already have the managers email as he was the one who expedited the retest of my used oil analysis sample.
Email inquiry sent to Wear Check.
One of the reasons the TBN is so high is because it was tested with the D2896 method. It's not comparable to most of the TBNs we typically see in VOAs which use D4739. Typically, we see a 2-3 point difference between the two (D2896 being the higher value), but I'm not sure I've ever seen a TBN this high. It's possible that the higher the starting TBN, the bigger difference there is between the two methods. I'm not sure. I'd be curious how much lower this oil's TBN would be if tested under D4739.
So for us less “chemistry-educated”, is the amount of sulphur in the samples considered excessive, or is this something that is average in pretty much most motor oils? All I see is visions of sulfuric acid eating away at my seals!
