HPL No VII Euro 10w20 15,000 Miles 2013 Elantra
What measured value shows that the oil has degraded?
I agree not running it until 100% used up. But with a TBN remaining of 3.3 and only a 10pt rise in oxidation. I don't think the oil was used up.
I did change the oil at the 15k mark as this was the first run of this oil, and i'm sure there was some residual oil from the previous oil ( castrol edge 5w40) in the engine for this oci.
I didn’t say it was used up, I said it has degraded primarily due to the oxidative thickening and TBN depletion. Degradation is a sliding scale 0-100%
Is it 50% used up? 75%? It really doesn’t matter as the cost of another UOA is more than just changing the oil. It’s served its purpose at 15k miles and the owner got his moneys worth by using a premium oil like HPL.
It’s done, rinse and repeat. Why push it farther to find out you exceeded the endpoint?
Why throw the oil away when the data shows it has plenty of life left? This oil isn't an off the shelf oil meant to compete on price. It doesn't behave like those oils. It's mean for extended drains, which it does exceedingly well. See my Durango 34k oil change.
I do agree that if @spasm3 were just looking at the color of the oil on the dipstick and not doing UOAs, then it may not be prudent to extend without real data. That isn't the case here.
Another factor, some people simply like to see how far an oil can be run safely. Now that I have lots of data for my vehicles, I wouldn't think of dumping HPL oil without extending.
@wwillson @RDY4WAR
Since the ester oil starts out with a virgin oxidation of 20-25. What condemnation point would be appropriate? 40-45?
Wearcheck suggests a condemnation oxidation value of 25. From my data, I believe the oxidation of HPL oils can be pushed further and I have, but 25 is a reasonable condemnation value if you aren't willing to push farther.
How is it driven? Can you post city and hwy % ratios? Grandpa style, conservative normal, conservative hard (some full throttle to get into traffic or hard acceleration on ramps, or hard.
This will be an interesting one for me, since I had a 2013 Elantra GT, It was my wife's car I took temporarilyover after she wanted a Rav4, 9 year and she still has it, and running great. I drove it for the last 5,000 miles before piston skirt aluminum debris went through the whole engine. First sign "The Hyundai Lifter Tick of Death". The 1.8 doesn't have bottom piston sqirters. A short tripper car that ran Walmart synthetic and Mobil 1 the last 7,500 miles.
All kinds of driving, mostly 12mile runs to and from work. Plenty of full throttle accelerations, but only warmed up. Engine has spent most of its life on 5w30. A little 5w20 early on. I ran the 10w20 as it is almost a 30wt and did thicken.
5W30 no-VII pcmo in it now. Amost always fram ultra or endurance filters.
@Mainia , how many miles on your engine at failure?
14,000 miles, and Hyundai order writter guy said I might not get a warranty engine because of the Fram Ultra on it. 5 milliseconds after he said that, I said in a paraphrase "The Magnuson-Moss Warranty Act says you must uphold my warranty with any name brand oil filter that has the correct filter number for the car, and don't to pull that BS on me". He said we will still have to talk to Hyundai, I never heard another word about after that comment. If I remember right later that day I got a call from the service manager they were going to install a shortblock and I said I want a longblock because you wont be able to guarantee cleaning out all the aluminum debris from the heads passageways. He said he will do a longblock.
It’s not oxidative thickening in this case; Dave has gone over this before in my thread on the No VII Euro 5w30 in my 3.5 Eco. The viscosity increase is essentially a work-hardening, as all base oils will thicken in use over time, even when there is no significant increase in oxidation. Oxidative thickening, IIRC the way Dave described, is rapid, significant increase in viscosity. Not from 9.0cSt to 11cSt in 10k miles, more like an increase from 9.0cSt to 20+cSt in a couple hundred miles. This series of oil, same as the CK-4 oil @wwillson uses, are truly incredible oils that defy what you’ve learned based of shelf stock oils. It’s legit.
