When I purchased my '07 Camry it had about 60k miles on it and a sticker from a lube shop stating it had conventional oil in it. The specs for the car call for 0/5W-20 full synthetic, so I changed out the oil and put in Pennzoil Platinum 0w20. I had read that PP is supposedly a great oil for cleaning out your engine of varnish. Recently I did a pre-vacation trip tune up on the car and replaced the oil with Pennzoil Platinum 0w20 again after a 4,200 mile OCI (the first since I originally replaced with PP). What came out looked exactly like conventional oil. Slightly thick and black.
As I just can't justify spending $30+ dollars on an oil filter cutter, I'm assuming the filter did its job. I'm also assuming that for the majority of the 60k miles prior to me having the car, conventional was being used. What I am curious about is if anyone else has seen how well synthetics clean out engines in a similar state over a longer period of time than my short OCI. Also, if there is a specific synthetic that I may want to try to help clean it up a bit. I'm not really concerned about any damage (so the conventional vs. synthetic debate doesn't need to be had), but I do like seeing clean fluid going in and coming out. It gives me that warm fuzzy feeling.
