Nick1994
$100 site donor 2024
Had my mechanic do wheel bearings on my Camry, ball joint boots were all torn up so it also got new Moog Problem Solver ball joints. Before the alignment, the car drove straight as an arrow, but the outer edges of the front tires were feathering a little bit. Rear tires wore fine, I've kept them rotated. It now drives just as straight as before. Had the Toyota dealer do the alignment.
I'm guessing the bad left rear alignment was due to getting rear ended on that corner in March. Although it could be worn bushings.
