I have a trashy 24" 3/8 x .050 x 84DL chain, which is a semi chisel and was used for demolition work. I was able to get it professionally re-sharpened, which it cuts excellent. Here is where I was a dummy. The prior owner ran this chain with a .325 x 7 pin rim sprocket, and it did cause wear on that rim. I never thought of this before I wasted the money on getting it re-sharpened. Now when I install this chain on a good matched 3/8 x 7 pin rim sprocket that is NOT worn, the chain binds and does not feel good. How do I re-dress or correct the drive links so that flow thru the rims sprocket better?
Again I already wasted the money or I would have just chucked it in the trash.
