Originally Posted By: BTLew81
One of my biggest takeaways from being a member here is that OEM is not always "the best." I'll catch a lot of flack for this, but case in point is my Mazda3. 5 speed ATX requiring Ford "FNR5" or Mazda "M-V." First drain/fill at 6k made me sick. Switched to Amsoil, and later Castrol Import, which I am running now. Shift quality is improved, and the subsequent drains look REALLY nice. Import MV is a reasonably priced fluid, proven, high quality, and has really impressed me. Much cheaper and more readily available than either OEM replacement.
I'm not advocating going against OEM. M1, Amsoil, and Castrol Import are all approved for my spec. It's just that I'm not sold that OEM is best. They are often a compromise...cost $$$
I must agree/admit that domestically-sourced "so-called" factory spec'ed servicing fluids tend to fair the lowest in terms of performance/price (seems to go to the lowest bidder always) and I can cite the same thing with a lot of "so-called" domestically sourced Honda fluids.
While I would have no choice but to go with HOnda Genuine PSF for dad's civic, I'm in the midst of switching dad's ATF type-Z to Castrol multi-vehicle imports and ditto with my wifey's 04 camry which calls for T-IV fluid. I've already switched out my MTF from factory fill to MTF-II which is imported from Idemitsu, the OE supplier of domestic Honda vehicles. It's semi-syn and the shift quality is really good. As it currently stands, Idemitsu already released MTF-III for all domestic Honda M/T cars in Japan and it's full-syn. According to user's impression, it shifts even better than MTF-II.
That's another biggest gripe I have re: NA factory dealership servicing for most of the so-called OE fluids are somewhat mediocre if you are to compare to the original specifications, incl. bulk motor oil frequently being used in stealerships.
My subjective observations.
Q.
