Quote:
I installed my stacked plate cooler before the rad cooler...I'm with onion on this one...get the heat out BEFORE it gets in the system.Plus I was always taught that oil to water is far more effcient than oil to air![]()
The coolest possible outlet temp for the fluid is going to be by routing through the radiator cooler then to the second cooler mounted out in front of the radiator and AC condensor.
None of the heat is "absorbed" back into the radiator. All that happens it the radiator rejects less heat because the temperature differential is less. i.e. the air in front of the rad is a little warmer. The radiator still rejects heat.
A properly functioning cooling system wouldn't even notice the difference.
