I take a sheet of heavy duty large foil the 18" width kind.
Rip off about 2ft turn edges up to fit grill.
The important part.
LEAVE about an inch of airspace on all 4 sides so heat from grill can escape.
Put grill on medium. put foil on grill. lay out entire pack of bacon on grill.
after 5-6min check if its rendering turn down to low.. if not wait a couple mins.
5min later or so. check again.. now is the crucial time.. bacon goes from oink to charcoal in only a couple mins.
Flip once when its almost done to crisp the other side (takes another min or 2)
Remove when done.. remembering that hot bacon appears less done.
turn off grill.
Pour nearly pure bacon grease off foil into container for later use.
Enjoy bacon.
Easy, keeps mess outside, no cleanup, whole pack in one go.
also better to pull off slightly early.. dont burn the bacon to get that last bit of white off.
a microwave will finish off 4 undercooked slices in 20-30s
pic is 12oz pkg of center cut store brand. almost done and on low, I have cooked 24oz pkg on same grill but its a squeeze.
The important part.
turn off grill.
Enjoy bacon.
