How to apply different themes in XP SP3?
Great Lakes
Apparently, if you have XP SP2, all you need to do is install this Universal UXTheme Patcher before you can change themes (use 3rd party ones):
http://www.softpedia.com/get/System/OS-Enhancements/Universal-UXTheme-Patcher.shtml
But it does not work with SP3. So, I found this one for SP3:
http://www.softpedia.com/get/System/OS-Enhancements/UxTheme-Patch-for-Windows-XP-SP3.shtml
But this latter one is just a single .dll file, not an installer, so what do I do with it? Do I still need to install the old Patcher, and then just copy over the .dll from the new (SP3) Patcher? Anyone knows?
If there is a simpler way to enable 3rd party themes in XP SP3, I'm all ears...
Thanks.
I do not know about SP3 and XP Themes since I have SP2 with XP Themes, but I will attempt to tell you what I know.
You need a patch as has been mentioned. Once you get the the patch you can download the themes and apply the settings under DISPLAY PROPERTIES.
I use customize.org for themes. http://customize.org/xpthemes
I use the http://customize.org/xpthemes/47990 theme on my system since it is a sleek setup. I also use Rocketdock for the icons, which leaves me with just that console, and a picture or wallpaper on the screen.
Hopefully this info helps.
Eric
