How Thrust Reversers Work
Central Coast, Calif.
I didn't want to contaminate the ignorance thread
so I'll post it here so that everyone can be ed-u-ma-cated.
I used to be a jet engine mechanic so I know exactly what the engines do when landing.
This is the basic way typical commercial planes work.
When the plane is coming in for a landing the landing gear is down and the flaps are down. the flaps add lift so that the plane can fly slower but stay in the air. Those two together make a lot of noise but you are still in the air.
When you hit the ground the pilot applies the brakes on the wheels, like a car, and pulls the throttles back. When the throttles pass "idle" the engines go into "reverse" and the further back the throttle is pulled the more the engine revs up and the more reverse thrust you have.
Thrust reversers typically work one of two ways, either "clamshell doors" or "cascading vanes and blocker doors". The engines still run the the same direction, in fact the engine doesn't "know" it is in reverse, it is done through routing air so that it goes out and forward instead of out the back.
Clamshell doors block the exhaust and route it out and forward. they are very common on smaller jet engines.
a couple of videos
http://www.youtube.com/watch?v=9Y6GAILFuew
http://www.youtube.com/watch?v=MqUJbpaTD6Y&feature=related
Cascading vane thrust reversers block the bypass air from the "fan" and route it forward, it is much more streamlined and cleaner then the clamshell design. (doesn't blast exhaust everywhere) the blocker doors block the airflow from the fan and force it out of the cascading vanes.
videos
These are the vanes
http://www.youtube.com/watch?v=dZ-wh8Kuh1M&feature=related
these are the blocker doors
http://www.youtube.com/watch?v=fGnrvHEvf4M&feature=related
turboprop engines change the angle of the propeller blades so that they are pushing air forward.
Thrust reversers can provide enough thrust for the aircraft to "back up"
http://www.youtube.com/watch?v=eSpazcmLc-Y
http://www.youtube.com/watch?v=MRcbJvy_blo
a few military aircraft can apply "reverse" in the air, but commercial planes have this locked out for safety reasons.
hope that helps
It looks like the blocker door mechanism would clog up with "jet junk"?
It's amazing how fragile both mechanisms appear compared to the forces that are acting on them.
I got my reverse thrust education from Microsoft PC flight simulators.
Reverse thrust is what caused Howard Hughes to crash his plane - something went wrong mechanically, and he reversed his propeller thrust while in the air. The controls broke and worked backwards.
Originally Posted By: LT4 Vette
Cool videos,
but what aircraft did you work on ?
I worked on F-16, B-1b, and C-130 engines. Neither of the fighter jets actually reverse but we have to study their function and systems in each phase of training.
If you have "jet junk" you have malfunctioning engines. there is not much to suck up once you are above or below the birds. you'd be surprised how clean the engines are. they get oily and have a little dirt/grime but you have to remember they usually fly in relatively clean environments, unlike ground vehicles. Military transports can land in nasty places but it's still dirt and oil.
most impressive aviation sight I ever saw was a B1 bomber about 300 feet overhead back in 2002... blew me away! nothing has come close to that.
very very little soot in the exhaust, maybe the same as the tail pipe on a newer car. only enough to get your uniform dirty.
The F-16 incident happened in an area that wasn't under the control of the tower. The F-16 didn't know the B-1b was about to throttle up (obviously).
