link.pdf
In addition, whereas the oil consumption volume per hour was 1.0 g/hr for oil
on the market, it was extremely large at 1.8 g/hr for the test oil. As mentioned in the previous
section, the NOACK of test oil 14 is in no way inferior to that of oil on the market, and because
the lubricant oil temperature during implementation of the engine test was limited to the low and
medium temperature ranges, it is believed that mechanical lossesdue to the ultra-low viscosity,
rather than vaporization volume, are the main causes of increased oil consumption. Moreover,
because of low viscosity, the seal property worsened due to lubricant oil at the cylinder liner,
and blow-by gas volume increased. There was also a large volume of oil consumption, and
points such as these suggest that sludge production may have been promoted.
… was found that ultra-low viscosity worsens performance in cleaning and in high-temperature
oxidation stability.
