On my 2004 Accord 2.4 5 speed I've been fighting cold engine valve clatter for the last 20k miles or so. I first noticed some valve clatter on a cold engine when I switched from GTS conventional to PP (both 5w30 weights). It was so noticeable I did a short change and went back to the GTX only to find it still clattered. Hummm thought I... must not have noticed that before...
I've tried GC, Mobil 1 0w30 Green cap, and even Amsoil 5w30 to no avail. I've adjusted the valves three times, the last time carefully setting the lash to a bit below spec to see if it helped. It did and reduced the clatter, but I still heard it for the first couple of miles when the engine was cold.
So yesterday I dumped the Amsoil and had bought some NAPA 5w30 full synthetic on sale so I poured it in. Didn't change the filter since it only had 5k on it (I know, I change too often!) So I drove the car this morning and zero clatter!!! Unbelievable! Why would this oil eliminate the clatter when several other high quality oils didn't??? This NAPA oil is made by Ashland so I suspect it's a variant of SynPower.
(by the way, the temp is 57F today in Seattle, pretty standard for recent weeks so I don't think it's the weather warming up for why the clatter is gone) The car has 56k miles on it and I'm the original owner. It's always had frequent oil changes and is in excellent shape. Once warm, the engine is nice and silent as a Honda should be!
