This is from my Lubes and Greases Newletter.quote:
Book Bits: How Particles Affect Fuel Economy
From the "How to Select a Motor Oil for Your Car or Truck"
Sooner or later, wear from abrasive particles and deposits from carbon and oxide insolubles will interfere with efficient combustion in an engine. Valve train wear (cams, valve guides, etc.) can impact timing and valve movement. Wear of rings, pistons and cylinder walls influences volumetric compression efficiency and combustion blow-by resulting in power loss. Particle-induced wear is greatest when the particle sizes are in the same range as the oil film thickness.
For diesel and gasoline engines, there is a surprising number of laboratory and field studies that report the need to control particles below 10 microns. One such study by General Motors concluded that, "controlling particles in the 3 micron to 10 micron range had the greatest impact on wear rates and that engine wear rates correlated directly to the dust concentration levels in the sump."
More information about the book "How to Select a Motor Oil and Filter for Your Car or Truck"
For more information about wear particles and filtration please see the BY-PASS FILTERS section on this site.
I don't care what kind of by-pass filter you are using(though I'm sure RALF will argue with me
So what I"m saying if you take 2 vehicles one with by-pass filter and one without, the one with the by-pass filter should run better and be more effecient at 100,000 miles than the one without.
While you don't see many engines fail even with excessive miles on them (200,000 miles) very few with those miles are producing the horse power and have significantly increased levels of exhaust emmissions.
This is one reason I'm a big proponent of by-pass filtration even if you don't keep your vehiles for more than 100,000 miles.
