Originally Posted By: Realtech214
2003 silverado 80000 Miles. how often to change brake fluid? I have never needed to add any fluid so I know there are no leaks
2 years for normal use, but every year if you have a serious big right boot. One of the main causes of caliper and even rare master cylinder failure is bad brake fluid.
It should be in the engine manual and might be 3 or 4 years if you use something very expensive.
