hey all bought new ngk 7751 for my 14 rdx from rockauto and i also bought that wire style type of gap tool. i was debating between the feeler gauge one and the wire style but decided with the wire
sadly my wire gap tool's closest gap setting is 0.044 and it seems that these plugs come pregapped at 0.043 (differing info but seems that ngk site says 0.043)
as far as i know my vehicle does not easily tell us the gap size, manual seems blank about this, some people say its supposed to be 0.044 but some say 0.043, i think could also be due to issues with what it is actually pregapped from factory as and the misinformation regarding that. i could be wrong but if ngk says this plug comes at 0.043 and seems to be the case, i just don't see why acura would want us to further the gap from a factory plug unless im wrong
so at the moment, i eyeballed all my plugs with my tool and as long as they slightly engage the wire tool surface i call it close enough to 0.043 since the gap would have to be 0.044 on my plugs to easily pass thru the gap tool. i know i could just gap them all to 0.044 with my tool but since they already came at around 0.043 i thought it would be easier just to keep it at that
so my question is if my plugs are ranging between 0.042 - 0.043 ish of gap is that fine? or should there not be that much variance between each other?
the reason i can't set properly is cuz my tool's closest setting is 0.044 so rn im eyeballing what i think 0.043 would be
thanks!
thanks!
