I ask for a couple, or few, reasons. One of them *IS* directly/indirectly related to the Volvo situation. It appears VERY likely (based on all things considered) that the Coolant Temp Sensor has been telling the Volvo's computer that the engine was cold when it either was or wasn't for an extended period of time. I think that this *may* have finally resulted in the end result of the engine running SO rich, i.e. dumping SO much fuel into the engine, particularly on hot re-start, that it actually would NOT start up. (The code for the CTS is on. 2. I noticed temperature fluxuation on the coolant temp gauge. 3. We smelled gas. 4. I believe I smelled gas in the oil.) So, I suspect that there is a LOT of gasoline in the oil... so much so, that some smoke was coming out of the tailpipe! (Again, suspicions as to gasoline. Not thick heavy smoke, no.. but these last two trips.. 1. It did that while running 2. It would not start back up when fully warmed, ran fine and strong when it did and 3. I noticed increased fuel consumption, enough so that the gas gauge has ticked down almost a notch.)
This has me with some concerns:
1. I am inclined to change the oil, and begin A-RX. Just cheap, regular oil.. perhaps Supertech, although I do not get why the site recommends Shell Rotella T.. (No Synpower or Redline or Royal Purple with ARX though, that I know. Maybe Supertech 5w30 is fine with it.) However, with all this gasoline that MAY be in there.. should I change the oil out first, THEN do A-RX? (Auto RX. I hear it cannot hurt anything!)
2. I know that gasoline is a cleaner - and also reduced engine lubrication, a la Seafoam in the crankcase. So, if all this gasoline is/was in the engine.. What did it clean, if anything? Some sludge? And was this cleaning beneficial?
