This is from the GM engineer.
“Fenske goes on to explain that the recall calls for affected units to have their oil replaced with high-viscosity 0W-40 Mobil 1 Supercar oil rather than the 0W-20 oil originally specified upon passing an inspection. Then, he uses his automotive engineering expertise to explain why using a different oil viscosity is supposed to prevent the engine failure issue.
It’s all about an engineering concept called the Stribeck curve. The Stribeck curve is a way of measuring proper lubrication by charting the friction coefficient on the Y axis and the Hersey number on the X axis. There are three distinct regions on the curve: boundary lubrication (high-friction, metal-on-metal contact), mixed lubrication (some, but incomplete separation between metal parts), and hydrodynamic lubrication (metal parts are completely separated by a layer of oil. Naturally, reducing metal contact decreases friction, making the Stribeck curve go down in the mixed lubrication phase.
The Hersey number measured on the X-axis is a formula that measures lubricant viscosity multiplied by sliding speed divided by load pressure. GM’s goal in using a thicker oil in the L87 engine is an effort to increase the Hersey number so the engine spends more time in the hydrodynamic lubrication phase of the Stribeck curve.
Fenske further explains why GM is making the switch from 0W-20 to 0W-40. Generally speaking, it’s inadvisable to increase the first number or decrease the second number in an engine oil’s viscosity, because it introduces the engine to a viscosity it isn’t designed for. However, increasing the second number isn’t as risky since the whole operating range of 0W-40 oil is within the operating range of 0W-20 oil.”
